Basically I bought this fan (Corsair Air Series AF120 Quiet) because of how good it is. Does it job amazingly but it seems to be very loud?
If I poke the fan and prevent it from moving, my case is near silent but if I am playing games, I want the fan there.
Any solutions?
https://linustechtips.com/topic/299051-case-fan-too-loud/
if the AF are PWM fans
you should be able to reduce the speed of the fan in MSI BIOS
if it just a 3 pin fan
looks like you might need to cut and solder a resistor
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4060706
I have a low noise fan adapter but I want adjusting speeds :(
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4060762
You can adjust a 3 pin fan but only to about 50%, most modern mobos allow it
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4061257
Anyway to get it lower?
Will a fan controller lower it?
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4074732
You might get it lower with mobo also. It depends both mobo and fan. Hardware controller can get it lower but limit is around 30%. You will need to get PWM fans for lower than that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4079568
You can set the fan speed from the BIOS.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4079579
This fan sucks :(
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4079877
I bought a super cheap fan speed controller on eBay for my air540, I just wedged it in the unused disk drive slots.
I set all the fans to about 25% and its near silent at idle. only my gpu while gaming makes any noise.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4080392
I've got one and yes I found it incredibly loud. I just opened up my motherboards fan controller and set a custom curve, so that it only spins a meaningful amount when you're in intensive gaming. If you turn it right down to near the lowest setting its perfectly quite, but when it spins up fully its very loud.
I think they're almost designed as CPU or waterblock fans.
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4080996
What cos it doesn't runs at 4v? What are you going for airflow or silence?
It's way too loud. I bought quiet edition for a reason and even at 50%, it's the loudest thing in my PC.
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4081019
The only thing I can suggest are be quiet pure wings fan as they are silent at 75% and at 100% they are quiet but have no motor noise.
Thing is fans are a lottery when you buy them. I've had 2 identical fans before and one has awful motor noise the other makes no noise
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4081479
I'm picking up 3 SW2 140mm fans, if they aren't satisfactory I'll be sure to report.
On another note, I'll have to agree with what @rentaspoon mentioned. I have two R2 fans from Fractal Design, both 140mm -- one is apparently louder than the other, at the same voltage.
The only problem with maximum silence is price, as the SW2s by Be Quiet! aren't cheap. What I'm hoping for however is good airflow, with low pressure noise ... something the Silent Wings 2 should offer. The "Silent" Fractal R2 fans are relatively quiet, but not what I had hoped for and they move almost no air at respectable settings.
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4087624
I'm really surprised that you consider the AF120 Quiet Edition loud. I was going to replace my front intake fans with the LED versions of Corsiar AF120s or SP120s. Below are the advertised stats for AF120 Quiet Edition:
Operating Voltage 7V - 12V
Performance at 12V
Airflow: 39.88 CFM
Static Pressure: .5 mm/H20
Sound Level: 21 dBA
Speed: 1100 RPM
Power Draw: 0.08 A
Another popular fan are Noctua NF-F12s and they are PWM controlled and Pressure optimised (ideal for rads/hdd cages):
Acoustical Noise: 22,4 dBA
Acoustical Noise with (Low Noise Adapter).: 18,6 dBA
Rotational Speed (+/- 10%) 1500 RPM
Rotational Speed with (Low Noise Adapter). (+/- 10%) 1200 RPM
Min. Rotational Speed (PWM, +/-20%) 300 RPM
maybe the NF-F12 with the Low Nose adapter would be a good choice?
Intel i7 4790K | Asus Maximus VII Ranger Motherboard | Kingston Beast 16Gb 2400Mhz RAM | Corsair AX860i Power supply | Corsair H100i CPU Cooler | Cooler Master Storm Trooper w/ window | Samsung EVO 500gb SSD | WD Black 2TB | Asus GTX980
https://linustechtips.com/topic/299051-case-fan-too-loud/#findComment-4087730
