Hi All
Just want to share my worklog. Begining of this year starting on first January i have been thinking of changing my rig. Previously im on the X79 platform and i love it. As time goes by X99 comes out and for me i think this is the best time to change my rig completely. Regardless of that i finish nearly RM30k ( that will be divide 3.2 for US Dollars) for all the hardware, software, water cooling system and buying some item that i thought i want to use but my idea keep on changing. Just intro i'm new to water cooling but not modding pc rigs as well as overlocking.This is also request from few friends that i know of here. Feel free to comment any of my build but just a note i purposely done this one OVERKILLed! as maybe some can be used in my future build. I know some will ask why i don't go for rigid tubing. IMHO i like it because it have that clean look but i dont know i just  dont like it and nothing else and further more i frequent changing lots of hardware. At first i ordered all fitting to quick disconnect then want to use all rigid tubing but i don't know why i change to the normal way using com fittings, tube and drain port. Let the project begins!!
I start to buy all the hardware for my my rig and order water cooling hardware later. Bought them and Test all the hardware but intro on my specs first
a) PC Spec
- Rampage V Extreme X99 ROG motherboard
- 5930k Intel Processor
- Corsair Vengence 2800Mhz DDR4 rams
- GTX 980 Strix in SLI
- Xonar Phoebus ROG Sound Card
- PLEXTOR M6 Pro 512GB SSD
- 2 TB Western Digital HDD
- 1300w Cooler Master SIlent Hybrids PSU
- Custom white sleeves
- Razer Chroma Keyboard
- Razer Ouroboros
- Razer Tiamat 7.1
- ROG PB278Q monitor
- Enthoo Primo case
- Bitfenix white 300mm lighting
- 12 unit of SP120 Corsair Fans
- 3 unit of AF140 COrsair Fans
- 2 unit of Darkside 3-Pin Dual Radiator Push / Pull 4x Fan Y Splitter Cable - Jet Black Sleeved
- Darkside 3-Pin Dual Radiator Push / Pull 6x Fan Y Splitter Cable - Jet Black Sleeved
- Bitfenix Y cable for molex
B) Water cooling
- EK Supremacy EVO Gold edition CPU Block
- EK ASUS Rampage V Extreme Full Board Cooling Block Kit - Nickel CSQ
- XSPC Dual D5 pump bay res
- Alphacool NexXxoS Monsta Dual 360mm Radiator Special Edition White - 80mm Thick!!
- Alphacool NexXxoS Monsta Dual 240mm Radiator - 80mm Thick!!
- Alphacool NexXxoS XT45 Full Copper 240mm Radiator
- 1 unit Koolance INS-FLTR04 Inline Coolant Filter
- 1 unit Koolance Flow meter INS-FM18D
- 2 unit of EK GeForce GTX 980 Strix Full Coverage Water Block
- 2 unit of EK GeForce GTX 980 Strix Backplate - Nickel
- 2 unit Bitspower Adjustable Aqua Link Pipe II (41-69mm) - White
- 12 unit Bitspower G1/4 Thread 90-Degree Dual Rotary Adapter - White
- 5 unit of Bitspower G1/4 Thread 90-Degree Triple Rotary Compression Fitting - White
- 2 unit of Bitspower G1/4" Mini Valve - Deluxe White
- 2 unit of Bitspower G1/4 Male to Female Extender - 30mm - Deluxe White
- 2 unit of Bitspower G1/4 Male to Female Extender - 40mm - Deluxe White
- 2 units of Bitspower G1/4 Male to Female Extender - 15mm - Deluxe White
- 5 unit of Bitspower Dual G1/4" Male / Male Fitting - White
- 16 unit of Bitspower Compression fitting
- 10ft of PrimoChill PrimoFlex Advanced LRT Tubing- Elegant White
- Iand Silver kill coils
- Mayhems Biocide Extreme
- IandH Dead-Water Copper Sulfate Biocidal PC Coolant Additive
Note: Some of cooling hardware is ondaway from store's in the US and some local dealer here . Below are the some of the item i already received
So is time for me to stress test the hardware first and a liltle overclocked have been done on my test bench as well of a liltle bit of gaming. See below picture of the hardware on the test bench
As of update yesterday i start installing my waterblock first but one of the block screw broke while im instaling the screw. See below because i overlooked the screw's. Like some say RTFM.
And later i ordered another one since im running on SLI also waiting now for it to arrive. Below is the finished product using the other block
I'm still waiting from some hardware from frozencpu, the update was it is stuck in customs. Funny for me it seems that here in my country we dont tax for cumputer item. 8 shipment using USPS none of them getting taxed but i just want to try out UPS to see how fast the item can reach, yes it is fast but i need to pay the tax almost half the price for the item i ordered in frozencpu.
Until i have my item i will continue the build log.. until then...
to be continue......
Mobo:Rampage v Extreme **Processor: i7 5930X @ 4.7ghz**Ram:Corsair Vengence 2800 16GB**GPU: GTX Titan X**PSU: 1300W Cooler Master Silent Hybrid**Hard drive: 512gb Plexton Pro SSD**Samsung EVO 1TB SSD**Case: Enthoo Primo** All razers peripehal
WC : Alphacool NexXxoS UT60 480mm Radiator ***Phobya V2 480mm Radiator!!***EK R5E Full Mobo WB***Nickel EK-FC Titan X with Black Backplate from EK*** Bitspower com angle fittings*** Primochill Hardline Fittings**Bitspower Dual Pump top and 200mm Tube Z with MCP655 pwm***Primochill PETG** Mayhem Dye
Follow me in instagram #grimmmreaper88
https://linustechtips.com/topic/297121-project-grimmms-blanco/
Ok, im hard.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033425
Cool build, followed
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033426
Oh my god that STRIX Water block is amazing.
Yeah.. i though Black at first, just go with my instinct for silver
Ok, im hard.
Thanks man.. :)
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033584
im still thinking about the loop that i will be going for. Below i  have draft the loops and i'm still undecided which one should i use. Any opinion would be great
Loop A - 76668d27-b50e-4dc7-879a-3407416ff2c2_zps
Loop B - 440a2b38-1bb9-412e-8e72-d79459e45c14_zps
just to add (my bad), im using a pump/res combo
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033616
[spoiler=]
i still think about the loop that i will be going for. i have draft it and i'm still undecided which one should i use. Any opinion would be great
I like B, but where are you putting the pump?
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033621
[spoiler=]
 i'm using a res with the pump attached to it. It will be at the 5.25 bay
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033624
ohhh... I've never seen that before :3
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033627
This is the pump/res combo im using
IMG_1209_zps9euz1ygk.jpgIMG_1210_zpsomqv9qjj.jpg?t=1421995525
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033648
That Strix block looks amazing!
Great job, I'll follow the buildlog.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4033897
Thanks man.. :)
i love to see water cooled builds, cant wait for more
Very soon.. i will start on Monday 01/26/2015.. :)
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4034366
Followed !! Looking forward for the white radiator  ;)
Very Very soon.. Thanks mate..
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4043151
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4043155
This looks sweet. I definitely like loop b more.
Thanks man and also for the loop suggestion
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4043160
Wow, what a rig thats gonna make!
I'd agree with loop B :)
Thanks man.. also for the loop suggestion.. i think is going to be B
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4043161
Hi Everyone
Just an update i have received my shipment today but the core item still in "departure status from origin" should be arriving soon maybe today or tomorrow 01/27/2015. Below are the 90% complete of my fittings and some item receive from frozencpu
IMG_1226_zps7hovaq4k.jpgIMG_1227_zpsfq86ionw.jpg?t=1422181582
Hopefully my last shipment and also the core item will arrive soon so i can start building it.
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4053825
edited
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4053827
Hey folks
My build is on going.. Sorry at the moment i cant post picture as im using my phone now.. Im doing a leak test and hopefully if everthings is ok i will start posting picture of the build.. No doubt some glich here and there.. Stay tune...
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4073531
Hi Guys
As much i hope everything when fine my second gpu is not detecting. I'm draining everything again and dismantling the gpu for some checking. Hopefully it is not broke.
Here are some picture of the build starting with the motherboard
i post some more later on till it end but for now im not in the mood as my other card is not being detected.. dismantling the cards just to see what's up..
Thanks for viewing
https://linustechtips.com/topic/297121-project-grimmms-blanco/#findComment-4080860
