what to do when first installing os
Go to solution Solved by soaringchicken,
does ninite download drivers for me or no? and why the website? im guessing cuz the other ones that come on the discs are outdated id assume?
Yeah the discs are outdated, Ninite just gets the basic programs for you like Google Chrome and stuff like that
Install all drivers for motherboard/GPU/etc. first
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Download all of your drivers for your components, and use ninite to download all of the basic programs you need
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Yup, like the others said, download the drivers for your motherboard/hardware from their websites (not from the CDs they give you!) and then you can start downloading Steam, games etc etc. :)
(never heard of Ninite suggested by @soaringchicken but after looking at it, it looks incredibly useful! I don't know if it uses the latest files, but oh well, updates can be run after I guess.)
what should i do after i first install my os on my build? can i go straight to internet browsing downloading steam and playing games?
yeah, download all drivers, maybe make an image of the system and after that go into downloading and installing games/programs
It always updates to the latest :), I learned about it through Linus a while back
how do i got about installing my drivers? im guessing my parts come with the driver discs?  and what is ninite?
askdjfasdf
I believe Linus uses it and Austin Evans too.
have not used it myself, but seems very helpful
Search Ninite on google to get the website and you'll figure it out. DO NOT use the drivers from the discs, download them from the manufacturers website
askdjfasdf
Ah, cool! Now that you mention I think I remember someone talking about Linus using it before. I'll have to check Ninite out when I reinstall Windows. All that convenience?  Seems too go to be true. :P
https://ninite.com/
As for your drivers, you will have to go to the websites of the hardware you own to download the latest stuff (don't do the BIOS though; if it ain't broke, don't fix it).
If you need help with the downloads or anything, just post here and we can help. :)
https://ninite.com/
hey thank you very much ill definetly need all the help i can get for my first build :P
thank you for your help! and thank you everyone else!
askdjfasdf
Why have you bolded(wd?) that?  Sometimes the driver on the disc (though it might be older) is sure to work or workarounds/bug fixes are easy to find with Google,  sometimes new drivers have hidden bugs, (the newest driver is not ALWAYS the best , hence the driver roll-back feature).
I would agree that 'normally' as the disc may have been produced months ago the drivers may well be superceded, so newer ones are usually available.
It is a 'rule of thumb' not a hard and fast rule that you should not use the drivers on the disc.
Oh and just as an aside not everyone has NIC drivers on a USB stick so good luck getting on the Internet to download drivers without a driver :) , (quite often Windows will not recognise a NIC).
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
