Nee help choosing the roght GPU
Solved by Imakuni,
So here we are: forget the 8gb crap. 4gb is PLENTY.
Anyway, given the fact that you have an ROG Swfit, you should stick with the SLI 970. Even if you dip below 60 fps, G-sync will cover you up. No reason to go for 980 SLI if you have it.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
4
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
