help (gaming desktop for 2000$)
Go to solution Solved by Archangel1994,
As a baseline I made this:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($317.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.98 @ OutletPC)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($146.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($599.99 @ Newegg)
Case: Corsair 780T ATX Full Tower Case  ($179.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($108.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($90.99 @ NCIX US)
Total: $1783.89
Generated by PCPartPicker 2015-01-19 06:50 EST-0500
Yes the case is expensive and I added the OS but this will give you a general idea of what to expect. Also if you switch to a less expensive case then you know how much you will have left.
For peripherals (If you need them) I recommend:
Mic: Modmic 4.0 or a quality desktop mic with stand like the AT2020
Headphones: HD519/ATH-AD500x/700x for open-back, ATH-M40x for closed back
Keyboard: A good mechanical keyboard. Corsair K70/95 RGB if you want RGB lighting. Otherwise CM Storm Quickfire is a solid mech keyboard series
i would like to have a new gaming desktop i have a budget of 2000$ i already have the GPU the windforce gtx 980 i also have a 144 Mhz monitor but i don't know how to mange the built so i can run games in ultra settings with a maximum number of FPS...
what should i have as CPU and motherboard and should i change my GPU ? with a 2000$ budget
https://linustechtips.com/topic/293925-help-gaming-desktop-for-2000/
A 144MHz monitor?
Holy shit I don't even want to imagine the power needed to drive that
xD
As for the build I can help you, I need the following:
- Currency (USD, CAD or AUD)
- Peripherals?
- OS?
- Special requests for the case/color scheme etc?
Also are you a silence freak or do you want a case that's a bit better performing?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
A 144MHz monitor?
xD
 I lol'd
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
See @Archangel1994 's questions and don't forget to follow your topics
Total: $1783.89
Total: $1783.89
Very nice rounded build. Will run like a beast with the 2x 980's.
Does the Ripjaws X Ram fit under the NH-D15? Not sure.
Yes it does, the NH-D15 has left out some fins at the bottom for HP RAM. My friend is running trident X under one now (And those are big) though one of the fans might need to be slightly elevated but that's no issue
Cool, then that combo will work nicely for OP.
A 144MHz monitor?
xD
- Peripherals?
- OS?
-USD
-i only have the GB gtx980 and the monitor now i don't know what i should buy to max out the Fps
-Windows
-black xD
-USD
-Windows
-black xD
Look at the build I posted. Black/red Build and the 780T also has a black version, let me adjust
Do you need peripherals?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.88 @ OutletPC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($128.99 @ SuperBiiz)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($119.99 @ Micro Center)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($124.00 @ B&H)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  (Purchased For $0.00)
Case: Corsair 750D ATX Full Tower Case  ($119.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($124.26 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($69.98 @ NCIX US)
Total: $1155.05
Generated by PCPartPicker 2015-01-19 07:35 EST-0500
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
