Graphics Card for Eyefinity, should i upgrade?
Coswar
I currently have 3 Dell 23 Inch monitors @ 1050 x 1068 (i think) which gives me something like 3500 x 1068 when i run them all in eyefinity. Atm i have a 6870 1GB but i'm thinking of upgrading due to bad FPS. I get a max of 55 and a min of 25 on Black Ops (1), even with the settings turned right down to lowest. Would a 6950 2GB have much of an Increase in FPS,over the large resolution?, because i heard it can run larger resolutions easier, or is there another card you would recommend? I can get nearly 90 fps on Blops with only one monitor atm, and I'd love to be able to 45-60 on all three!
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
My advise is to go with a GPU from the 7000 series from AMD or if you can wait a 8000 series... A 7950 or 7970 are good? But if you are on a budget maybe the 7870 will do good enough... All better than what you have, and better then 6950.... Whats your budget?
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
A 7950 would be perfect as it has a large memory bandwidth to run at that resolution.
My budget is fairly limited, maybe 200£ max, I've looked at amazon and i can get a 6970 for less than i can a 7950....which would you go for? 50£ is the difference in price. The 6970 is 2GB and 7950 is 3gb.
Main Rig:
Home Server:
HD 7870 or GTX 660 Ti.
And your monitors are 1680x1050 probably.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I don't think the 7870 would be enough , i have the 6870 and there seems to very little improvement, as for the 660ti , well it's nvidia.
Main Rig:
Home Server:
For Black Ops a 7870 would be enough. But for other games, it wouldn't be enough for a triple monitor set up. Single monitor yes. You could always just Google this :P
Lol, i have Googled it , and then i came here due to a lack of info. ;) And I don't know, 7870 only has 1GB of vram, not really enough for Eyefinity. Plus i won't just be playing Black Ops that's just what i'm playing at the moment. And I can't really switch between single and triple. My setup is the same as this:[ATTACH=CONFIG]n2385[/ATTACH]
Main Rig:
Home Server:
7870 has 2GB of VRAM. And it's not a lot weaker than a 7950.
Also, new nVidia cards support 3 monitors mode.
What is the rest of your pc? We suggest graphic cards like blind, maybe your cpu would bottleneck or sth.
I have a question, what are the frame rates that you are looking for and what graphic settings are you thinking for your computer games? I would recommend a 7970 or wait for a 8970 because for multiple monitors the best single GPU especially from AMD for multi-monitor setups is a good choice.
I get around 45-55 FPS on BF3 with settings on medium at 5760x1080 with an overclocked 7970. A 6950 would make quite a decent improvement from your 6870 however I would recommend a newer card. You might be able to sell your 6870 for around 30-70 pounds. Then you could probably get a 7950 for about 220 pounds or if you want to stretch your budget you could get a 7970 for about 280 pounds.
7870 has 2GB of VRAM. And it's not a lot weaker than a 7950. Also' date=' new nVidia cards support 3 monitors mode. What is the rest of your pc? We suggest graphic cards like blind, maybe your cpu would bottleneck or sth. [/quote']
Ok well I've got a Phenom II x4 840 O'Ced to 3.8ghz ,8gb Corsair Vengeance 1600mhz and an Asus M4A88T-M mobo.
As for frame rates , I would like a minimum of 40 , so not that high(but i can't deal with the min of 25 that I'm currently getting), and i don't mind running on the worst settings. Both the 7970 and the 8970 are/will be out of my budget...that's why i looked at the 6970 cause even though it's last generation , it's still the best of last generation, and a reasonable price.You can't tell me that a 7870 is better than a 6970?!
Main Rig:
Home Server:
Actually mate, http://www.anandtech.com/bench/Product/548?vs=509
Wow! That is amazing...there must be such a big jump from past to current gen...I am amazed! :0
Well it looks like it all boils down to price now...it looks like i can get a brand new 6970 from ebay for €165, which is a great price, but il see how much i can get a 7870 for.
Main Rig:
Home Server:
Yeah looks like i can't get a 7870 for less than €240.....which is a bit too high for me tbh.
Actually i can on amazon...il look into it, they'll still be more expensive than the 6970 though.
Main Rig:
Home Server:
What are the benefits of using a 7000 series card over a 6000 series one? (Apart from obvious ones such as power consumption)
Main Rig:
Home Server:
Basically just power consumption and heat. Also better performance and you'll probably get support for a bit longer if anything goes wrong. Could you sell your old card and spend a bit more on a new one?
