Hey, I need some advice on when building. How do I test my PC components before I put them on my case? So I put the motherboard on top of its box, I insert the CPU, Ram, CPU fan, and GPU? What do I do next? I know that you need to commect the CPU fan and insert the PSU on the 24pin connection. Where else do plug it? If I do not have an HD monitor, do I just connect my GPU to one of those Vga or DVI connectors?
https://linustechtips.com/topic/292513-testing-components-before-build/
Connect the DVI/VGA/HDMI/etc cable to your GPU when it's plugged in. Make sure the required cables for anything you see on the motherboard's plugged in. Note, not all motherboards will magically recognize a GPU so you might be forced to boot off of the onboard GPU to work your BIOS.
But yes, your steps all look fine to me. Make sure to ground yourself too (touch the PSU while it's plugged in when working with your PC).
1. On top of MB box.
2. Connect all power cables.
3. Connect CPU fan.
4. Start PC by shorting with anything conductive.
5. You can use DVI or VGA.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
Yes, you can use the VGA or DVI cords.
What I did—without having to short things to turn it on—was place the mobo on box, hook everything up outside of case and then hook the connectors of the case's power on button to the mobo and  (cords are usually long) then press the button on the case.
  • 4 months later...
Sorry to revive this post, but the alternative was to start up a whole new onw...
Say I'm doing a custom water cooling loop on my CPU and GPU. My GPU comes with a stock air cooler, so no problems there, but how do I keep the CPU cool while I'm testing the components before installing the cooler? Should I just install the CPU cooler in a small isolated loop, and then complete the loop once I've confirmed that all the other components work?
Thanks!
RabidBurn
TS3 I frequent: ts.absgaming.net feel free to join!
Use the stock cooler that came with your processor. If you have a 2011(-3) cpu, then use a 212 evo (or anything lying around)
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
  1. Install CPU and cooler
  2. Install RAM
  3. Install GPU
  4. Install all PSU connectors, 24 pin, 4/8 pin EPS connector, PCI-E connectors
  5. Plug in monitor
  6. Short out computer power pins with screwdriver
Remember to flip the switch on the PSU
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
I didn't put in my GPU when I built mine, but others do.
  2. Install RAM
  3. Install GPU
  5. Plug in monitor
What do you mean by step 6?
Read the manual for the motherboard, there should be two pins where you will eventually plug in the power button from the case. If you don't have an onboard power button on the motherboard itself, you can short out those two pins with anything metal (say, a key or screwdriver) two turn on the computer.
RabidBurn
RabidBurn
Oh, wasn't familiar with your terminology.
Guest
