I have just build a really cheap pc and I have 2 monitors that I want to connect up to the computer. The specs are a8 6600, gigabyte f2a88xm-ds2 and the rest doesn't really matter. one monitor is a samsung s20b300b and one is a s20a300b. One is going to be connected by div-d single link and the other vga but when i plug in the vga monitor the screen powers one but doesn't display any image. When i go into the screen resolution in windows it says that the screen is there and working but in real life its not. WHAT IS THE PROBLEM! i am also wanting to connect up another s20b300b by usb but the adapter hasn't arrived in the mail.
Thanks
https://linustechtips.com/topic/291643-please-help/
check for the correct input settings on the monitor.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/291643-please-help/#findComment-3754850
are you using a dvi to vga adapter by chance?
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/291643-please-help/#findComment-3754855
at the screen resolution page
just below the screen resolution drop down menu
do you see another drop down menu
check if you are able to extend the desktop
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/291643-please-help/#findComment-3761563
  • 3 weeks later...
Yea it just thinks that it is a monitor but you cant do eyefinity on it though
Right, Eyefinity was a massive pain in the bollocks for me aswell when I had my rig hooked up to 3 different display devices. Try disabling one of your monitors through CC and then putting the USB monitor as your secondary / primary, see what that does. (Not in eyefinity, this is just to see if it works outside of EF)
https://linustechtips.com/topic/291643-please-help/#findComment-3961394
 The USB to VGA works fine it is the standard VGA port on the motherboard that is not working
https://linustechtips.com/topic/291643-please-help/#findComment-3961511
