Posted January 14, 2015 hi guys , actually i have this build right now .i7-4790k @ 4.8Ghz 1.252v cache 39Ghz Asus vii HeroCorsair Dominator platinum 16Gb 1866 CL9 1.5v (2x8gb kit) only two 2 choices : 1- Corsair Vengeance Pro 16GB (2 X 8GB) DDR3 2133 CL9 V1.5 Dual Channel Memory Kit Timing: 9-11-10-30Voltage: 1.5V 2- 2 kits of G.SKILL Trident X Series 8GB (2 X 4GB) DDR3 2400 CL10 V1.65 Timing: 10-12-12-31Voltage: 1.65V so , what's better?2 sticks of vengeance pro (2x8gb) @ 1.5vor 2 kits of trident x (4x4gb) @ 1.65i know 1.5v of ram is better for cpu overclocking& i know 4 sticks of ram (2 kits) make a bigger load on cpu imc .so any suggestions? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 I'd say go for the 2x8 for future upgradeability. Specs: CPU - Intel i7 8700K @ 5GHz | GPU - Gigabyte GTX 970 G1 Gaming | Motherboard - ASUS Strix Z370-G WIFI AC | RAM - XPG Gammix DDR4-3000MHz 32GB (2x16GB) | Main Drive - Samsung 850 Evo 500GB M.2 | Other Drives - 7TB/3 Drives | CPU Cooler - Corsair H100i Pro | Case - Fractal Design Define C Mini TG | Power Supply - EVGA G3 850W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 I would go with the Corsair... no not because I am a fanboy but because it's a dual kit, thus dual channel. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 stick to dual channels kits Z97 do not support quad channels kit and some mobos may not boot with that many DIMMS Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible. Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 You have a Z97 mainboard, that means you will be best off with dual channel RAM and you can not profit from a quad channel setup, you'd need with your DDR3 X79. And unless you need the amount of RAM like 32GB I'd go rather with a 16GB dual channel setup. Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 I would go with hyperX fury ddr3 2x8GB kit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Dual kit 2x8 Gb so then you have room for improvement in the future Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author by the way guys ,the Trident x is a kit of (2x8Gb dual channel) & i'm thinking of 2 kits...... all will work as a dual channel the vengeance & trident have samsung ic's too. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 by the way guys , the Trident x is a kit of (2x8Gb dual channel) & i'm thinking of 2 kits...... all will work as a dual channel the vengeance & trident have samsung ic's too. why do you need 32GB of RAM for? Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible. Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 by the way guys , the Trident x is a kit of (2x8Gb dual channel) & i'm thinking of 2 kits...... all will work as a dual channel the vengeance & trident have samsung ic's too. So it's not 4x4Gb, but 4x8GB? They will perform the same, so either go with the cheaper set, or with the better looking one. If it's 4x8GB, the price will be a fair bit more, so unless you need that much RAM, go with the Corsair kit. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author sorry .6 replies in 5 minutes made me write it wrong ... sorryit's a (2x4gb) about the trident..sorry again2 kits = (4x4) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 sorry . 6 replies in 5 minutes made me write it wrong ... sorry it's a (2x4gb) about the trident.. sorry again 2 kits = (4x4) stick to dual 8GB DIMM kits for later upgrades Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible. Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author thanks for all replies . but i'm comparing between thememory voltage vs number of sticks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 thanks for all replies . but i'm comparing between the memory voltage vs number of sticks all mobo will support 1.65v or 1.5v RAMs just that you should not mix 1.5 with 1.65 DIMMS Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible. Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 by the way guys , the Trident x is a kit of (2x8Gb dual channel) & i'm thinking of 2 kits...... all will work as a dual channel the vengeance & trident have samsung ic's too. Well go for the one that looks the best. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 all mobo will support 1.65v or 1.5v RAMs just that you should not mix 1.5 with 1.65 DIMMS You can also adjust the voltage in the bios Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
