Samsung Galaxy S 5 Active won't connect to mobile data
Solved by ShadowCaptain,
So I have a Samsung Galaxy S 5 Active but when I connect to any wifi and then disconnect it refuses to connect to mobile data. I have turned data in and off and turned smart switch on and off. I even turned on and off roaming. The model number is SM-G870A and I am using it on the T-Mobile network. I live in the Twin Cities which is their 2nd largest market so it's not them. I have cellular services like talk and text. I am running unrooted android 4.4.2 with touchwhiz as well.
have you made sure that the APN settings are correct?
