I know its been asked so many times but I don't really find good enough answers for me to do it! If possible I would need a step by step on how to over clock my graphics card. Let me know if you could help me.
My setup is:
Intel I7 4770k (over clock to 4.4)
Asus Z87 Formula Motherboard
Corsair 750 rm power supply
6 fans in my case
Corsair H105 for my CPU
I think I should be ok with temps because of my set up but I know everything could be a problem!
Thanks Nick
https://linustechtips.com/topic/289081-asus-gtx-970-help/
https://linustechtips.com/topic/289081-asus-gtx-970-help/#findComment-3924716
Im sorry the writing wasn't clear enough to be understood!! Are gigabyte actually that good??
Gigabyte G1 windforce 970/980 cards are the best 970/980 and soon 960 cards.
Mine runs are 1400mhz stock (gig g1 windforce 970), no overclocking :P
Yes it is "That good"
Edit: Since it's long as Africa (Lol pun), and has 3 metal fans it stays pretty cool and quite.
Windforce has a patent pending (It's the most unique GPU casing I've seen that does something other than pretty colors)
(Waterforce is a sceme to rob rich people, windforce worked too well)
Gigabyte does things with GFX cards other than slap colors and cheap fans onto them.
Edited by marat569
https://linustechtips.com/topic/289081-asus-gtx-970-help/#findComment-3924867
