Did my headset break?! Help pls
MattP123
So, I got up from my chair and set my headset on my desk like I always do. I got some food. I came back to my desk put my headset back on and there is no noise in the right ear cup. :/ What should I do? I have unplugged them and plugged them back in. I also restarted my pc. Astro A40's + Mixamp Pro, I have had them for a little over a year. I don't know what to do, so any help is appreciated.
Thanks.
Try pushing the wires in different directions around the ear cups. If you can hear sound at a certain angle, then the wire's come disconnected/loose.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Can you plug in the Astro's straight into your PC?
And use a different pair of headphones with your Amp?
Just to eliminate one or the other of being broken..
I plugged them into my pc. Didn't work.
I tried different headphones. Does work.
So it isn't the amp.
That didn't work either :/
Honestly it sounds like somewhere the cable detached from the ear piece. I've had that happen with a few pairs of ear bud headphones.
They're not ear buds, but did you get them working again?
I didn't bother I just bought a new set. Wasn't worth my time.
