H220 pump death, help me understand
Solved by airdeano,
My questions are:
Would the too much thermal paste lead to a dead pump? My understanding is "absolutely not" but I could be wrong.
What could have caused a bad pump? Caused is the question, not I just got a bad one.
I put on the stock 4790k cooler and I get high temps, what are the standard temps under load and idle for stock?
Suggest me a new AIO cooler please. I am feeling a H220x. There is no budget but it needs to fit in a Fractal Define R4 with the mobo.
- no
- defective designing on swiftech's part (too easy cavitation and run pump dry)
- stock HSF idle would be 5-15° above ambient
- H105 because it is simple. H220x is the same as H220 just with a patent work around.
