Running Intel Extreme Stress Test with a Enermax Liquitech 240mm and am hitting a max of 81°C @ 65% fan speed on two SP120's. Is that about the right temp for this cooler?
CPU:4770K @ 4.3Ghz @ 1.290v
Cooler & Fans: Enermax Liquitech 240mm (IC Diamond 7kt) with 2x SP120's @ 65% (900rpm)
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/285969-cpu-too-hot/
4.3GHz @1.290V.
You lost. Unless you are running auto voltage? Because that must be the issue. Near 1.3V for 4.3GHz doesn't sound right at all.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883298
4.3GHz @1.290V.
My 3570K had to have similar voltage applied to hit 4.3GHz.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883344
turn off turbo boost and test again the temps
is that voltage the most stable for your CPU OC speed?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883354
That seems okay to me, just don't let the temps get much higher or you will be in the danger zone
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883360
At 1.290 most people hit 4.5 - 4.6GHz.
1.31V nets me 4.6GHz. Haven't went lower but 1.25V should get me 4.4 - 4.5GHz
Although I think Op should go as far as one can and if they hit 100C in benching that's far enough.
Games will be much lower running temperatures.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883366
Right. I wasn't denying that you were right, but rather, I was implying the OP may have a bad chip if further testing/adjustments doesn't yield better results.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883377
It is possible that the CPU is a bad overclocker. If OP is bothered he/she could get it swapped.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883479
Intel wouldn't take it back would they since its been OC'd
| F@H STATS |
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883507
How would they know though?
The OC threshold is 1.5V if you are covered by the performance tuning plan.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883553
So if u don't go over 1.5v they don't care?
| F@H STATS |
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883564
Essentially yes. As long as you have the performance tuning plan though.
But then again how are Intel supposed to know what clocks it has ran all its life.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883597
1.5Vcore will kill the cpu on air cooling. I would only give 1.45Vcore max on custom loop.
1.5V will not kill it. 1.8V will.
https://linustechtips.com/topic/285969-cpu-too-hot/#findComment-3883604
