Basic Web Dev questions
Solved by Ciccioo,
Question 2: What attributes does the element have? Write the attribute names
html attributes are those:
<tagname attribute1 = "value1" attribute2 = "value2" attribute3 = "value3"> content</tagname>
so your answer is wrong because you just listed the classes of the element, which are not its attributes
Question 3: What happens if you leave out a citation sign for the attribute class?
you can try yourself
spoiler alert: it will only recognize the first class (learn) and it will try to interpret "easy" as an attribute
