DT990 600 Ohm or 250 Ohm? (For Gaming) Which is harder to drive?
OneManWolfPack5
^^^^ PLEASE HELP
600Ohms is harder to drive.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Is there a reason you are even considering the 600 ohm version? What's wrong with the 250?
The 600Ohms are harder to drive, but you could have easily asked that in your previous topic
Molex to SATA, lose all your data
mb get 32ohm version and dont buy an amp at all?
If one does not fail at times, then one has not challenged himself.
The 600ohm version is intended for equipment that requires something to be drove with high impedance (redundant but true)
This is usually reserved for studio and legacy equipment.
Basically, if you don't know which one you need, then you don't need the 600ohm version.
Error: 410
Even at 250ohm you don't need an amp unless you like to blast music. I have the 250ohm DT990 Pros myself and have no issues driving them -- even from my iPhone. I usually sit around 50% volume.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
well guess what, I have 990 edt. and I need them on 3x gain on o2 amp to get a satisfying sound out of them.
Good for you, fact remains that they get deafening for most people from integrated audio.
but but my experience with them quantifies everyones experience..
