I need a little help
Go to solution Solved by Godlygamer23,
Not initially. You need your graphics card's drivers.
Again Trolling is not funny if you are doing it too obvious
If not trolling yeah it will work
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/282979-i-need-a-little-help/#findComment-3841466
https://linustechtips.com/topic/282979-i-need-a-little-help/#findComment-3841470
