VirtualBox not Using the Right OS Bit-Rate
Go to solution Solved by QueenDemetria,
I started using virtual box on my note book that runs Windows 8.1 64-Bit but virtual box only gives my 32-bit options... I installed the latest X86 version of virtual box but it doesn't seem to change the issue.
Make sure that Virtualization is enabled in the bios(you can use CPU-Z to see if it is). If it is enabled, then I have seen people say that re installing Virtualbox fixes it(didn't fix mine). I went back to Version 4.2.6 to fix my VB(Apparently there is problems with the latest 4.3 versions).
"Of course, its trash," Luke, 2014
Thank you so much I now have 64 bit options...
