Where should I put my MSI case badge on the Phantom 410 red?
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/276011-help-me-decide/
Front bottom
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3747762
Put the case badge at the bottom left of the front of your case, like where I put my Corsair case badge from my RM750. It's not in the way, looks like it belongs there, and I just think it fits really well!
Edit: I don't want to hijack your thread, but I applied two custom vinyls to my case! You should consider doing something like this!
http://i.imgur.com/34q8CBH.jpg
http://i.imgur.com/VtrfGjf.jpg
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3747787
I have mine on the inside of my case
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3747817
Back in its box.
Case badges are nasty.
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3748888
Inside the side panel of your case, so you know it's there but don't ever have to look at it.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3748894
depends on your taste, try the positions temporariky with double sided tap on different positions & go with the one you lik eth emost, Most reccommended opinion would be the dead centre a little to the bottom in the front or the right hand side of the front panel
Details separate people.
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3748901
In the very center of the front panel.
The phantom 410 is a weird shape at the front. and the case badge is a hard plastic
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3750363
I was thinking about doing some custom air brushing but I don't have the nozzle or the paint. All I have the is airbrush compressor
https://linustechtips.com/topic/276011-help-me-decide/#findComment-3750402
