Hello All,
Happy Holidays...can i still say that?  Anyway...
CPU: Intel Core I7-5960X 3.50GHZ
MOBO: ASUS Rampage Extreme V
MEM: Ripjaws 4 Series 16GB PC4-24000 Quad Channel DDR4 (X2)
For Now -- eventually want 32MB
HD/SSD: 2x Samsung 840 PRO's
Current GPU's: EVGA GeForce GTX 780 Ti Dual Classified Superclocked W/ACX Cooler x2
I want 4 GPU's because I want to attempt 3 4K monitors, 3x ASUS PB287Q 4K's ...
Do I try and get 2 more 780Ti's, do I go and get 4 Titan Black Signatures, 2 Titan Z's?  or 4 GTX 980's?
I have been told it "CAN'T BE DONE"  ... What i want from all of you is...
WHAT IS MY CHANCE and WHAT 4 CARDS (or 2 if titan z) will give me the BEST Frame Rates
p.s. I promise to test and benckmark the CRAP out of it.
p.p.s. I may need some help with the over clocking too.
I don't care about COST I want PERFORMANCE!!!
Thanks all
Jeff.
https://linustechtips.com/topic/269599-gpu-help/
triple 4k is lunacy and 4 way sli scaling is so bad that you might aswell just use 3 cards... not to poop on your parade or anything. Youre just wasting money dude.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659832
980's, but I don't recommend it. 3-way is more than enough even for 4K. 3X 4K, none of these are going to get a reasonable FPS.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659840
He's talking about 3x 4K you understood? As in 3 4K monitors.
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659845
I know, I fixed my post.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659849
4xSLI is not recommended. Sometimes you get lower performance with 4 GPU's compared to 3 GPU's.
I think 3x4K is something that will not happen very soon..
I asked a hypothetical like this earlier and got answers like I would maybe pull this off with highest end hardware on not that demanding games on low graphics.
I would stick to 1 panel for gaming now..
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659857
4 980s
Just fyi in some games 4 GPUs will perform worse than 3.
Also games will be unplayable at triple 4k, unless youre planning to play stuff like minecraft, lol
https://linustechtips.com/topic/269599-gpu-help/#findComment-3659869
Not raining on my parade, and nothing wrong with saving money. Thank you for the info!!!
https://linustechtips.com/topic/269599-gpu-help/#findComment-3660599
Got it! So no triple 4K! No matter how much money I throw at it! Awesome! Thank you ALL for saving me some $$$
Okay how about Triple ROG's!!! 2560x1440 I believe?
Still triple cards I assume?
You could run that with your current setup, however if money is no issue for you I'd say go for 3x 980s
https://linustechtips.com/topic/269599-gpu-help/#findComment-3660680
imagine 2x970 give u butter smooth fps for 3x1080p. ..
yes triple sli 980 for tripe rog
Ps: if u want to throw money. Just DDDOOO it
https://linustechtips.com/topic/269599-gpu-help/#findComment-3660687
