Hey guys,
I'm starting to notice that my boot up speed (windows 7) is alot slower than before. I got the PC around 2-3 months ago, up until about a week ago the time it took to go to the desktop after typing my password took less than a second, but now it takes 5-8 seconds at least... I have Windows (ultimate) installed on a SAMSUNG 840 EVO 128gb SSD, My CPU is the Intel CORE i7 4970K @ 4.4ghz and I have 8gbs of Corsair Vengeance RAM.
My thought is it's because my SSD is almost full (2.54gbs left). But I'm no expert so some help would be greatly appreciated :)
https://linustechtips.com/topic/268198-boot-up-speed-slowing-down/
Hey guys,
The reason is the samsung SSD. Sorry man, you own junk. Sell it if you can and replace it with a kingston.
Google Maps my location! 4th house from the corner on the left!
Dafuq man?
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
Samsung SSDs are much faster and more durable than kingston.
Kingston SSDs are actually pretty bad.
It most likely is because your SSD is full.
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
Dafuq man?
Especially an 840EVO I mean come on, that Samsung Nand man.
He's the forums new cokeman troll. And he's at it again.
And OP if it's near full, that's likely the reason.
And don't listen to him. While I'm personally a crucial customer, you samsung evo is a great product
Yeah I noticed every one of his posts is rude and offensive...
You need about 25/30% space left on it to keep it running smoothly (so I've heard somewhere)
Your SSD being almost full should be the main cause, but you can try disabling some startup programs in "msconfig.exe", disable or set to manual some safe services that delay the start in "services.msc" and disable some 3rd party scheduled stuff in "tasksch.msc".
cool! thanks!
Ok thanks! appreciate it!
Yes, like the others said, create a 20GB partition and keep it empty, that is what i did and it worked.
Also run Glary Utilites to clean up your registry, and delete junk/temporary files off ur SSD. Then run Disk Cleanup (windows) to clean up windows update backup files.
Hope that helps
And yes, Kingston sucks
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
