So, I honestly hate this new lesson our physics teacher gave us. Freaking law of universal gravitation, which is like 6.67x10-11 times the product of two masses divided by the distance squared. I honestly hate this freaking formula because it's so difficult to understand. I'll give you a problem.
Calculate the force between two touching grapefruits each with a radius of 0.08 metres and a mass of 0.45 kilograms.
I tried using the formula for law of universal gravitation but I keep getting the wrong answer. I was so pissed in class, i nearly cried. Was there something I did wrong? So after I squared the distance and multiplied the two masses together,  I divided the mass by the distance, then I multiplied that by the second part, the 6.67x10-11. But the teacher is getting a different answer as me.
https://linustechtips.com/topic/267829-physics-help/
We're on that right now. It's easy IMO. I get most of it.
I'll see if I can find something like that in my phys book.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/267829-physics-help/#findComment-3636826
If it's easy, how come I'm not getting it? I'm genuinely sick of it.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636835
you have to take double the radius, because you have 2 fruits ;)
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/267829-physics-help/#findComment-3636839
Show your work?
are you using (2*(.08))^2 as your radius?
Yes. Then, I multiplied the masses together and got 0.2025 KG as an answer. I divided that by 0.16^2 and got 7.91.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636845
Yep, What Luka said. From what I think "r" means it's the radius between the two objects. Since they're touching you should have the radius of both the objects together giving r= 0.16m
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/267829-physics-help/#findComment-3636854
Yeah, I then squared 0.16 since you have to and got 0.0256 m.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636865
heres your answer
52.78E -11
https://linustechtips.com/topic/267829-physics-help/#findComment-3636873
now, is terry really 16...
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/267829-physics-help/#findComment-3636887
hes 13... :)
https://linustechtips.com/topic/267829-physics-help/#findComment-3636891
hes 13... :)
how are you people so sure?
https://linustechtips.com/topic/267829-physics-help/#findComment-3636896
You're entering your calculations wrong. If you're using a TI be sure you put brackets at the end of your xEn notation numbers, that could be affecting your answers if you're doing  something like 5E-11/r^2
I got the same answer of 5.27E-11  5.27E-10
If that's still wrong then ignore it because your teacher must have made a mistake, this isn't very complicated and there's nothing fancy you can do here.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636901
heres your answer
52.78E -11
But my teacher wants to see the work. Right now, I'm stuck on Fg=(6.67x10-11)(7.91)
hes 13... :)
No I ain't. Where did you get that assumption?
https://linustechtips.com/topic/267829-physics-help/#findComment-3636903
G* (2m)/4(r^2) = G * m/2(r^2) = 52.78E -11
https://linustechtips.com/topic/267829-physics-help/#findComment-3636904
I have a Casio calculator, the FX series.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636906
umm, for some reason, thats what everyone thinks here :P
https://linustechtips.com/topic/267829-physics-help/#findComment-3636907
thats not 7.91 its 35.something ;)
https://linustechtips.com/topic/267829-physics-help/#findComment-3636926
Yep, did that in October, it's not too tricky is gravitation.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/267829-physics-help/#findComment-3636928
Yeah right. My calculator, when I divided 0.2025 by 0.0256, got 7.91 something.
https://linustechtips.com/topic/267829-physics-help/#findComment-3636936
wait i did it wrong, its 7.91. are you using your G correclty?
https://linustechtips.com/topic/267829-physics-help/#findComment-3636946
dude no, it's (FMM)/r^2 not F(MM/r^2)
you're getting the wrong answer because you're doing g(.45^2/.16^2) instead of (g*.45^2)/.16^2
thats two exactly the same expressions
lol, whoops you're right
still have no idea what you're doing wrong
https://linustechtips.com/topic/267829-physics-help/#findComment-3636966
https://linustechtips.com/topic/267829-physics-help/#findComment-3636974
