Fastest WiFi plan in Australia?
Xamurus
What are some of the fastest internet plans available in australia?
*EDIT*
Home ISP connection.
Don't live there but I hear that Aussies get the shaft for Internet access options.
"Fastest WiFi plan in Australia?"
Do you mean mobile broadband?
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
first off, i believe its internet plan/provider??
wifi is just the means with which you use it by.
anyway, i dont know myself, basically the best plan is just move to europe. they have insane speed internet for cheap.
or somewhere in the US with google fibre. (amazing deal, especially their middle tier option)
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
Whirlpool forums, and then broadband search.
Search engine for Aussie ISPs
@Xamurus
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
thats what i was thinking, either cellular service or australia's version of crapcast.
-Jim Hensen
depends on where you live
4G is extremely fast but the data caps are horrendous compared to a fixed line plan
There's also fixed wireless (part of the NBN) which at it's peak can do 25 down/5 up in terms of speed
Most places have ADSL2+ but in some cases the exchange might not be enabled for it so you'll just get regular ADSL instead
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
*EDIT*
Go to the NBN site and see if it has been rolled out in your area then you can get 100/40 unlimited data from TPG for $90
i7 4790k | ASUS Z97 Gryphon | 8GB Corsair XMS3 1333Mhz | Asus Direct CUII GTX 770 1267/3829 | Stock Cooler | Antec Neo Eco 520W | WD Green 1TB
Silverstone TJ08-e | Klipsch Promedia 2.1 | Razer Tiamat 2.2 | LG 24EN43VS | Razer Naga (2010) | Razer Lycosa (2010)
Planned PC Upgrades: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=325661&action=wish_lists
If you mean mobile internet instead of wifi, then all the mobile carriers have 4G data only plans, although Vivid Wireless (now owned by Optus) has better value plans though not true 4G currently.
I think Telstra is considered the fastest, but it will depend a lot on the main area you are using it.
