Hello.
Is it worth to pay 33€ more for 1866MHz RAM speed when 1600MHz is cheaper for 33€? Is the performance of 1866MHz big in comparison to 1600MHz? Both are 16GB CL9 Kingston Savage.
The PC is gaming / video editing oriented
Thank you very much for replying.  :)
https://linustechtips.com/topic/265170-ram-speed-scale-with-cost/
Wont it be too warm if i overclock it?
ram doesn't really get too hot
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
If you can overclock to 1866 on stock voltage, you'll be fine. The difference between 1600 and 1866 is about an extra 1-2FPS and that's if you're lucky. Not worth springing the extra on the slight chance of an extra frame.
does it affect video rendering?
