Help with CPU stats
Solved by Spev,
Well this program is probably giving you the wrong reading, because 2.4GHz is wrong.
Try using CPU-Z and it should say 3.4GHz
That's weird...CPU-Z says 3331.06Mhz...Easy Tune 6 is the software made for my motherboard so I'm not sure why it would be incorrect -______-
anothertealtiger ·
Mumintroll ·
Posted in Programs, Apps and Websites3 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3 -
IAmAndre ·
Posted in New Builds and Planning8 -
4
play_circle_filled
Latest From ShortCircuit:
