Hello everyone, so i have a work to do at home until tuesday where i must use Xampp. So after having to solve the port 80 problem due to skype and disable the http.sys, i did get Localhost with Apache to work. Now everytime i use localhost be it admin trough Xampp panel or not it keeps saying "It Works". I already tried changing in the original index.php but i ended up deleting it, and created a new one with the same syntax as a txt.file thinking that it was the problem fix (header('Location: '.$uri/School) which is where i currently have the work. Whoever can help do it directly and comprehensively, since google answerers arent even talking about xampp in windows and look like dont even know what apache is.Thank you
Groomlake Authority
https://linustechtips.com/topic/260770-xampp-htdocs-indexphp-problems/
I get the whole stream of conscious thing, I do it too, but its really hard to understand your dilemma in the OP
My solution has always been to listen to port 81 for xammp
In httpd.conf (note that it's file extension is conf)
Listen 81
which should replace a very similar line in httpd.conf
I've never had do delete anything like http.sys why did you do that?
Also what wolfsinner said.
