Quiet Static Pressure Fans
Matimo
How has no one mention these...
http://www.amazon.com/Scythe-GentleTyphoon-D1225C12B5AP-15-120mm-Silent/dp/B001Q6RUVO/ref=sr_1_1?ie=UTF8&qid=1417376828&sr=8-1&keywords=gentle+typhoon
Eloops, multi frames, Air penetrators, apache/viper/hyperboreas, twiter pressures/magmas are all good too
I guess, because they are hard to find.
Air Penetrators are great case fan, but I found them to be perform pretty bad on a Heatsink, they Just don't push that much air.
You can get black noctua fans.
I would recommend noctua or noiseblocker for pressure and quiet.
What model is that, I'm liking the black noctua fans, might get those too
CPU: Intel Core i7-4790K 4.0GHz/CPU Cooler: Arctic Cooling Freezer i11/Motherboard: Asus Z97-PRO(Wi-Fi ac)/Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866/Primary Storage: Samsung 850 Pro Series 512GB SSD/Secondary Storage: Western Digital BLACK SERIES 2TB HDD/Video Card: Gigabyte GeForce GTX 970/Case: Fractal Design Define R4 Blackout ATX Mid Tower/Power Supply: Corsair 760W/Optical Drive: Asus Blu-Ray Reader/Operating System: Microsoft Windows 8.1 (64-bit)/Monitor: Dell U2713HM 60Hz 27.0" Monitor
industrial PPC nf-f12 or nf-a14
I use the corsair SP on mine but you can definitely hear them when the machine ramps up..the noctua fans are the best but the industrial ones are loud. If yr going the noctua get normal ones if yr not building a beast
My normal ones max out around 1200. The black ones look much better and sound the same at 1200 but, with more head room. I'm a gamer so I don't care how loud fans are while gaming. As long as they don't sounds annoying like my corsairs.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
