So the battery in my M2 MacBook Pro is swelling and I've been looking for a replacement to fix myself the only one I could find is the M1 Pro 14" battery and I wasn't sure if it is compatible with my M2 Pro.
https://www.ifixit.com/products/macbook-pro-14-2021-a2442-battery
https://linustechtips.com/topic/1570737-m2-macbook-pro-battery-compatibly/
I have the M2 Pro chip 14" MacBook Pro
if you have warranty go use that. since its an apple product I doubt the m1 14'' battery connector would be the same as the m2, as the m2 uses more watts anyway I think, it wont be enough juice anyway, I doubt they are the same Wh also
