Suitable air cooler for 4.0Ghz overclock?
Solved by Excon,
I see. Yeah that's what i think i might have to do. I might look around and see if there are any light mods I can do like file the rear fans screw holes upwards a bit allowing me to push the rad all the way to the top, but the L9i just sounds convenient lol
And also isn't the h60 the same length and width as the h80i with thickness being the only difference? Atleast that's what Corsair's website told me.
That is correct, Im not to family with the SG09 so I just spent a minute looking at a bunch of them for clearance with something like a H60 and I dont see any issues.
