Corsair Graphite 780T Cooling
Solved by MrKickkiller,
Perhaps ,that would be +1 pressure and work with convection.
1 problem though. Bottom intake is most probably not filtered ==> dust.
I think any config will grant you great results. The delta should only be 1/2 degrees celsius.
That's basically margin or error.
Featured Topics
Jaw709 ·
Posted in General Discussion3 -
OllyOllyOxycontin ·
Posted in Troubleshooting2 -
Arpharazon ·
Posted in Troubleshooting1 -
2
3
1
jimmyrbk ·
Posted in Graphics Cards2 -
WUPHF ·
Posted in LMG Sponsor Discussion2 -
6
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
