2k Monitor suggestions
mman360
I'm looking for 3 2k monitors with slim bezels to create a nice surround gaming experience. I would prefer to keep them between $300-400 a piece. If anyone has any suggestions please let me know.
I would go with the pb278q, it is slightly over budget, but it is ips, and I wouldn't recommend getting a tn panel over $130 (besides possibly the rog swift). fyi you should follow this topic.
TN or IPS?
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
Thanks for the suggestion, Ill keep it in mind and thanks for the tip, Didn't see that.
TN or IPS?
Honestly, i'm not sure, correct me if i'm wrong but if ips has better viewing angles, i think it would make more sense for surround gaming.
Yes i'm newer to this.
The Asus PB278Q is 2560x1440 and is not IPS.
http://www.asus.com/Monitors_Projectors/IPS_Monitors_Products/
Check there all the IPS monitors by Asus, choose the size and resolution.
