Best Fans for H100i Push/Pull
Solved by extremescouter,
Noctuas NF-f12s are always a great choice. They are nearly silent, and perform well. Static pressure fans are always best for rads, and the nf-f12s are the best you can get, if you can bear the color. Are you doing push/pull for the noise? The extra performance with push/pull really doesnt warrant the extra price, and Linus actually suggests going for only pull. Learn more about his opinion here:
Featured Topics
