Scratched my case! Help!
Solved by W-L,
What color of plasti dip do you think will match my case color? a gunmetal grey or black?
Definitely the black the gunmetal is just a fairly dark colored grey, if you want it to closely resemble the original color. Just a tip if you do masking or taping on the case be sure to create cut lines before peeling off the tape because if you don't it can peel if the surrounding plasti-dip with it.
