Is it overclocked?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499597
Your GPU has overheated, you may want to wait a bit before you start up your PC again
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499598
Hello people. My pc just crashed while playing far cry 4 and when it rebooted it had green and blue lines all over the screen does this mean my gpu broken??
maybe its a corrupt driver but its more probable to be  overheating
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499607
Your GPU likely overheated. Leave your PC off and unplugged overnight and in the morning try turning it on again.
"Rawr XD"
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499621
To prevent it from happening again change your Max Temp of your GPU lower so  your PC turns off before theres damage to your GPU
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499653
I don't think it's overheated it's water cooled and yes it's overclocked but I'll try leaving it off for now thanks.
Did you put on the water block on right? Heard that has happened to a few people.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499666
I brought the gpu pre done with the block about a year ago I think and never had many problems.
Ok, so undo the overclock, and let it sit overnight and try turning it on in the morning
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499712
What GPU?....
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499761
At first glance I would've said yes, but others are suggesting the your GPU is OCed too much and so that's probably what it is.
BTW, is the letter "N" too expensive? Because it looks like you couldn't afford one on the end of "broke" in your thread title. :P:D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/255597-help-is-my-gpu-broke/#findComment-3499813
