Will it bottleneck?
Go to solution Solved by gilm0re3,
Nope. You should be just fine.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467548
Nope, not at all. I'm not sure how much of an upgrade a 550 to 750Ti is though. You can swing for a R9 270 or 280?
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467564
Nope.
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467568
For me is quite an upgrade, I should get 30-40 more frames in games than now (in higher settings)
I was thinking about getting R9 but it was too complicated for me so I stick onto Nvidia
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467621
Won't bottleneck at all. tbh i7 with a 750ti is pretty unbalanced.
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467624
How so?
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467628
I will get the Shield soon, so thats why
Ah i see enjoy your shield then. i've wanted to try it for a while.
https://linustechtips.com/topic/253081-will-it-bottleneck/#findComment-3467688
