Hello, I have an issue with my graphics, I first noticed this one afternoon while playing a graphics intensive game, I computer just shut off and rebooted. All signs points to there my be an issue with the graphics card which is gigabytes gtx 590. This is what I have done, ran prime95 no problems at all, next I ran valley and other  graphics benchmark software and every time after 5 minutes computer shuts down. card is not overclocked temp dont exceed 45c.
My system is
motherboard P9X79 Pro
Cpu: 4930K @ 4.8
Graphics Gtx 590
Mem: 64GB
Power Supply Corsair  HX1000
OS Windows 8.1
Corsairs 256 SSD X2
https://linustechtips.com/topic/246718-graphics-issue/
My system is
Cpu: 4930K @ 4.8
Graphics Gtx 590
Mem: 64GB
OS Windows 8.1
Corsairs 256 SSD X2
Heck! You've got 64GB of RAM? What the heck do you do with all of that?
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386370
Where are you reading your temps...
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386372
Open up as many tabs in your internet browser as you can and then open up another windows and do the same and never shut off you PC. That or some sort of massive professional level editing and rendering.
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386391
Well, I know what most people would do. But I was curious of what he does. ;)
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386401
software and fan sensor placed near gpu
Wait what?
You placed a temp sensor near the GPU and are reading it with software?
That is NOT how you monitor a GPUs temperature. That is extremely inaccurate.
Use something like Open Hardware Monitor or Aida64 to monitor the temperature of the GPU die. That is the temp sensor directly underneath the GPU core, and it gives you the proper temperature reading.
If the temp sensor you placed "near it" is at 45C then I can guarantee you that your GPU is overheating.
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386414
Wait what?
I had this psu for abouot 2 years
Wait what?
i will try it....
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386437
As Windows usually is set to restart by default on BSOD type stuff, download BLUESCREENVIEW, and see what files are the cause of the issue if its shown, and then tell us what files it says have been corrupted causing a restart.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/246718-graphics-issue/#findComment-3386531
  • 4 weeks later...
