Answer this question
Thanks
The Asus UX305 has an Almighty Intel core M-5Y10 0.8GHZ, GPU Intel HD 5300 Windforce, SDD 120GB, Passively Cooled, 1920x1080 Matte Screen, An Fantastic ICEpower Audio Making my House Shake and Having more ports then a MacBook btw this not an advertisement.
https://linustechtips.com/topic/243502-math-problem/
JKJK
@Trik'Stari you do know BEDMAS right?
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/243502-math-problem/#findComment-3334646
O.K so 40+40=80, 80 x 0= 0, 0+1= 1. But that answer is not correct. x comes before + so it is 40x0, + 40+1. So 41.
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/243502-math-problem/#findComment-3334672
Wat... No it isn't?
40 + 40 x 0 + 1
40 x 0 first
leaves 40 + 1
41
I always forget order of operations damnit. Part of the reason I hate math
Dubs are better than subs
https://linustechtips.com/topic/243502-math-problem/#findComment-3334689
Remember PEMDAS, people..
41..
PEDMAS? Haha that's funny, we use BODMAS in the UK (or where I live). What does the E stand for?
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/243502-math-problem/#findComment-3334697
..how..
No parentheses, was thinking "no parentheses, start left to right". Again, hate math so much, even did it with a calculator and got 41. >.<
https://linustechtips.com/topic/243502-math-problem/#findComment-3334726
https://linustechtips.com/topic/243502-math-problem/#findComment-3334745
If no parentheses and multiplication sign, start there.
:P
I still don't see why it's done like that. I've never understood how it made sense to start in the middle of a problem rather than from left to right, unless there are parentheses.
https://linustechtips.com/topic/243502-math-problem/#findComment-3334763
Because. I had my teacher explain it to me once, but like all classes I never listened.
https://linustechtips.com/topic/243502-math-problem/#findComment-3334797
the e is for exponent.
Parenthesis
Exponent
Multiply/Divide (left to right)
Add/Subtract (left to right)
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/243502-math-problem/#findComment-3334803
Parenthesis
Exponent
but WHY. Parentheses I get, but multiplying and dividing before adding and subtracting makes no sense to me.
https://linustechtips.com/topic/243502-math-problem/#findComment-3334826
To be honest, I do not know why. In school, I just learned why the rules are, not why they are (then again, I never paid attention in anything but History and Band).
Desktop <dead?>
https://linustechtips.com/topic/243502-math-problem/#findComment-3334840
Math doesn't care where you start. You will always get the same answer (as long as you do it right)
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/243502-math-problem/#findComment-3334843
https://linustechtips.com/topic/243502-math-problem/#findComment-3334849
Not true, using the "order of operations" you get the answer of 41 to the OP's problem, however if you do it from left to right you get
40+40=80
80x0=0
0+1=1
https://linustechtips.com/topic/243502-math-problem/#findComment-3334864
Think of it this way. You have to keep like with like. This make sense? And multiplication is just a shorthand way of doing addition. So you have to do the multiplication first in order to get it into a form of addition.
Example: So 5 x 3 is actually 5 + 5 + 5. It means add three fives together. So now that we have done the multiplication, everything is in terms of addition (hence like with like)
So 5 x 3 + 5 is actually 5 + 5 + 5 +5
^^ NB! Don't apply this logic to more complicated problems. It will probably breakdown at some point. Just use the rules you are taught.
And it doesn't matter which way you arrange it. 5 x 3 + 5 == 5 + 3 x 5 == 5 + 5 x 3 == (5 x 3) + 5. They all give you the same answer.
Edit: When I mean math doesn't care which way you do it, I mean you can rearrange the equation and still get the same answer.
https://linustechtips.com/topic/243502-math-problem/#findComment-3334923
