Hello!
I recently was trying to quiet down my PC, and I removed two case fans.
I now have three case fans. Two intake, one exhaust.
I haven't seen any significant temperature increases, so I'm a bit confused.
Shouldn't I need more fans?
Who says vanity is dead... maxsoley.com
https://linustechtips.com/topic/240738-only-3-case-fans/
Why not do the opposite of your current configuration.
Because negative pressure is bad as it attracts dust. Positive pressure reduces the buildup of dust.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/240738-only-3-case-fans/#findComment-3300331
Is there any reason that I should need more fans?
More fans can move air at slower speeds than less fans. Less noise.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/240738-only-3-case-fans/#findComment-3300703
How are your in-out CFMs? I have also 3 fan system, 1x200mm intake at 70.5cfm and 2x140mm exhaust at 58.7cfm. Still positive pressure and its cool and quiet-ish.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/240738-only-3-case-fans/#findComment-3304028
I have three Corsair AF140 LED (White) fans, which I have undervolted to 7v, instead of their usual 12v. I'd imagine that the two intakes bring in about 55-60 CFM, and the exhaust sends out about 25-30 CFM.
https://linustechtips.com/topic/240738-only-3-case-fans/#findComment-3304562
Looks to be fine. You don't really need extra exhaust unless your CPU feels to get hot during load and adjusting its cooler has no effect. But three fans in your config is fine too. I build a rig to friend with same config and it works, even under overclock and stress test.
https://linustechtips.com/topic/240738-only-3-case-fans/#findComment-3304601
