Skyrim FPS meter?
Go to solution Solved by TheKDub,
Fraps is a good one, I find that in games where there is a built in FPS meter having fraps on only drops the fps by 1-2, so its no big deal.
Some games are able to show FPS after you typed a console command, so I was wondering if Skyrim had something like that too?
If not, what is the best way to monitor your FPS?
Is Fraps not that 'heavy' of a program, that I would be able to run it and still see FPS?
Or is it possible to use Bandicam too? (Since I already have that installed)
Details:
Skyrim on PC.
Windows 7 (64 bit)
https://linustechtips.com/topic/239383-skyrim-fps-meter/
https://linustechtips.com/topic/239383-skyrim-fps-meter/#findComment-3282497
There's no console command but if you just open Fraps and have it set to show your fps you won't have a performance impact.
Alright, I'll install Fraps and give it a go. Thanks for the advice
https://linustechtips.com/topic/239383-skyrim-fps-meter/#findComment-3282543
