Cpu way to hot.
Solved by Faceman,
Prime95 is perfectly fine to use with Haswell, you just have to set voltage to manual/constant/override.
The bigger problem is your H100i. It is a well known problem that the H100i doesn't mount properly and it often requires a washer mod to fix it. Even then, sometimes it doesn't work, but for the most part, it helps.
http://forum.corsair.com/forums/showpost.php?p=623994&postcount=3
