Is this Mini itx build ok for 1100$ Cad
Solved by asusfan,
Please Dont me a itx build "Will heat up fast" "No upgrade opportunitys" i am aware and i want a small console like gaming pc.
Hello i am new around here i watch his videos so im not a stranger
http://ca.pcpartpicker.com/p/Nw2Lbv
this is my build please let me know if this is good?
pretty ok, however expensive drive, i think if your going for one drive then a SSHD (hybrid drive) would be better and save a lot of money, its half the cost. and then you can put that money you saved into a fully modular PSU and even better graphics card.
the Asus Strix comes with 6gig of ddr5.
check out the Seagate SSHD and you can get a 1 TB drive in a 2.5" size drive.
