So I've been trying to push my gtx 590 to see how far I get. The base clock of the card is 612 MHz and I have managed to bump it up to 800 MHz successfully. The problem is when running benchmarks There is no difference between the scores at all. I've been using Unigen Valley and Heaven,1080p at maximum settings but consistently get scores from 972-990 every time no matter what clock speed.
I use MSI afterburner to set my clocks and I haven't done anything to the voltage which seems to be set at a max of 913V by default. Surely there must be some kind of bottleneck somewhere?? or maybe I'm doing something wrong...
system specs are:
Motherboard: Asrock Fatal1ty H87 Performance
RAM: 2x4GB Kingston HyperX Beast @ 1600 MHz
CPU: Intel i5 4670k @ 3.4 GHz
PSU: Corsair 750W
GPU: ASUS GTX 590
any help or info would be great :)
https://linustechtips.com/topic/233815-gtx-590-overclock-issue/
system specs are:
PSU: Corsair 750W
GPU: ASUS GTX 590
sub 1000 for that card is stupid low... my 650ti boost gets about 1923
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/233815-gtx-590-overclock-issue/#findComment-3195171
Check, go watch something like Afterburner to see what your core speed is during a benchmark.
You are correct, the drivers were stopping responding without me noticing and returning the clock speed back to default, am now being more careful watching the speed while I BM :) Thanks
https://linustechtips.com/topic/233815-gtx-590-overclock-issue/#findComment-3195188
My temps are consistently at ~70 degrees at both clock speeds. Shouldn't be throttling at that temperature.
How are you gettinf those temps? O.o my 590 was constantly at 85-90°C and my case is very well ventilated!
Also your scores are very low. Check at what speed its running at with the afternurner OSD and not tge build in valley one.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/233815-gtx-590-overclock-issue/#findComment-3195191
I have seen it get to 90 before in the weirdest of places :P Borderlands 2 menu for example, I find it gets too hot if it's rendering lots of frames for example i can play a very demanding game at 40-70 fps and it stays around 70 degrees but if i play a less graphically intensive game it can render 300+ fps making it run super hot. It's a bit weird. my case is very poorly ventilated also.
https://linustechtips.com/topic/233815-gtx-590-overclock-issue/#findComment-3195233
