connecting me headphones to a controller
thesoldier108
hi, i have an xbox 360 controller connected to my pc with dongel, i want to connect to it my headset. how? will it work?
tnx
p.s. first post
why not just use the original y splitter?
xbox 360 one is 2,5 mm
And I don't think he has the one that came with the controller or he would've used that one
i mean use the y splitter with the 2.5 adapter
Huh, you're right. I don't know why they wouldn't :huh:
and if my headset has a 1 3.5 mm connector?
Sorry, apparently only microsofts own headsets work.
so is there a way to wireless connect my headset to my PC?
should i open a new post?
