So heres an idea, We all (or mostly) build our own PCs here, and we almost certainly all (or mostly) have a custom PC, naturally they are not without their problems and sometimes things go wrong over time, so I am wondering am I the only one who just lives with some little things not working quite right, so I Thought I'd make this thread, the basic idea is to explain what little problems your PC has and how you manage to deal with/live with them on a daily basis.
I'll start by saying I have a Enermax T.B Apollish fan in the top of my case (I actually have more than one the rest are fine, this one is a bit dodgy) and it doesn't start up for some reason. to fix it I generally just spin the blades myself if I got the case open anyway and it starts from there, or I start upping and downing the voltage from my fan controller which eventually kicks it into life.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/
Fan noise. Don't have enough money to watercool.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289768
Driver issues and loud H100i stock fans and a load others like bent USB 3 header on my mobo means no front panel USB3 for my r4
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289770
Mt 2TB seagate green drive, when not in use it spins down, then when you click on something for instance a film you hear it spin up and it takes about 30 seconds to launch in VLC, good idea for energy efficiency, but a royal pain in the ass when being used to SSD speeds in regular use.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289849
one of my Corsair SP fans clicks as it spins. I'm gonna buy some more, when i get $$.
“Obstacles are those frightful things you see when you take your eyes off your goal.”    -Henry Ford
Please do BOINC. no matter how small a contribution it can make a difference.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289903
My graphics card often whines like a mother, but I just crank up the volume to drown it out.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289956
After making sure everything in my build is silent.. I've started to hear the PSU Fan and the HDDs D:
Missing one of my rubber grommets at the back of case (for watercooling hole).
GPU looks a little skewed/droopy from the weight of the card.
Also Nvidia won't let me use my 3 1080p monitors in surround (should have gone AMD).
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289978
Graphics card backplate blocking one of my front usb 3.0 connectors on the motherboard, so it can't be used
Coolermaster fan for evo 212 runs at 100% so every time i start up i have to load up a program to set it at a lower speed (only a temporary cooler until custom water cooling loop is installed) I wear headphones to make it quiet.
When built new computer, i didn't do fresh install of windows so lots of things don't work (was very busy at the time) (microsoft office says that i've installed it on more than 3 computers and won't work so i'm currently using word pad :) )
RAT 7 cursor sometimes locks up on a x axis (rarely but still happens)
Middle finger twitches sometimes and I accidentally right click (on my g9 i had a border next to right click so i could rest my finger on to prevent this)
Messed up painting one of my xbox controllers ages ago so it's forever sticky until i decide to fix it =]
First world problems....
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-289985
I got 8gigs 8x1gb sticks of ECC DDR2 Server ram and nothing to put it on  :(
It was 14$ on ebay and i tested on a friends server they all work great  ^_^
Also got a HP wx4000 workstations mobo that has x2 PCI-E slots and runs on LGA 775 and nothing to put it in :(
It was 22$ on ebay and works ^_^
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290004
Stupid case, full of holes for watercooling that you can't even put in and taking off front panel to install a fan took me around 4 hours...
My fan's cable was missing 2cm from connecting to motherboard so i had to put tons of cables from psu to it so my fan is 100% on all the time, like a freaking vacuum cleaner ......
My 2x4GB Kingston HyperX t1 aren't low profile even tough i ordered those so i have no idea how will i install hyper 212 evo later down the line... also they look really bad.
AMD Radeon 7870 Gigabyte OC / Intel i5 3570k / ASrock Z77 Pro4 /Samsung 840 EVO 250GB / WD Blue 500GB 7200rpm / Kingston HyperX T1 2x4GB 1600mhz / SeaSonic 520w M12 / Thermaltake v4 Black
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290171
Go into the bios and look for CPU Fan control and set to "silent" mode, I had to do the same until I figured out that option was in the bios.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290254
True, I never bothered to check the bios for that option. It hasn't fully driven me crazy yet haha
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290265
My sisters wifi card the key is if its not working restart the pc until it does lol
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290309
My PCI ports aren't very secure so when I tug on my audio cable just a bit, it moves my sound card and causes my computer to hang. It gets quite annoying during skype calls if that happens.
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-290991
Extremely long boot times. A super crappy graphics card.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-291021
I still have a non-modular power supply that makes cabling my PC a pain in the rear.  I can't wait til that AX760 gets here.
Current Rig: i5 3570K @ 4.2 GHz, Corsair H100i, Asus Maximus V Gene, Asus GTX 970 Turbo, Patriot Viper Black Mamba 8 GB DDR-3 1600 (2x4GB), Sandisk 120 GB SSD + Seagate 500 GB HDD + WD Blue 1 TB HDD, XFX 750W Black Edition, Corsair 350D - https://ca.pcpartpicker.com/b/cbxrxr
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-291051
I have that same x axis lock problem with my rat 5, so annoying, but it has never happened in game so I don't worry,
also my south-bridge gets hot so I installed a blower type fan on the back of my psu to cool it, it is very loud even running at only 5 volts
AMD R7 1800X, H100i GTX, AMD Radeon RED DEVIL 5700XT, ASUS STRIX B350-F GAMING, 16gb DDR4 3000, 1Tb, 2 X SEAGATE 1Tb, Coolermaster V1200 Platinum, NZXT H440 red/black, STEEL SERIES AEROX 3, DUCKY X POWER COLOR RED DEVIL KEYBOARD, Microsoft xbox 360 wired controller, LG ULTRAWIDE.
https://linustechtips.com/topic/22911-pc-problems-you-live-with/#findComment-291153
