help configuring server - no motherboard display output
Solved by Ssoele,
You always need to have a GPU, is it a dedicated card, iGPU or one on your motherboard, you need at least one. Even after the installation you will need one, or the system will just not boot.
yes,
or get a usb monitor, they do exist.
That will not work, the system will not boot as it will only see it as a display and not as a GPU.
Featured Topics
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning1 -
Xrniu ·
Posted in New Builds and Planning2 -
8
3
bleedpurple ·
Posted in Storage Devices2
