Hi guys, I have a XFX Radeon HD 6990 which runs at these temps
Idle: 45-52 C
Load: 86 C
Standard profile, so the fan only comes on at around 85-90 C up to 50+% otherwise it's quiet.
I've bought Arctic Cooling MX-2 thermal paste, and wanna switch out the stock one, since it's helped on other GPU's I've had,
however research shows that AMD says the 6990 has some special compound, which MX-2 probably can't beat anyways?
Should I do it? Will it have a positive or negative effect? Anyone tried?
Quick comments, throughts, ideas are very much appriciated!
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/224429-radeon-hd-6990-replace-thermal-paste/
Doesn't the paste's performance degrade over time? I'll say the "special" paste is actually not very special. Re-paste your 6990.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
New paste, no point in not doing it.
Yeah, pastes turn to crap over time.
Wow, thank you SO much for the quick replies!! I've had really good experience with it on other cards.
Should i apply in a pea size for the gpu chip, or do a cross?
Which do you think is best with MX-2 on this card?
-Also, any idea how many years XFX warranty is on this card? - Never switched bios or OC'ed it.
