Which fans are better?
I need a good quiet 900D. I'm having Noctuas but I need three fort the front.
Why can you not use noctua fans for the front?
https://linustechtips.com/topic/223032-which-fans-are-better/#findComment-3055954
Cost.
Oh...
Well then according to specification the gentle typhoon 1450rpm (because the SP quiet edition also runs at 1450rpm) will have a bit higher airflow and static pressure, while being two decibels quieter.
Don't get high performance edition of corsair fans, and I wouldn't get anything above the 1450rpm version of the gentle typhoon because of noise level.
https://linustechtips.com/topic/223032-which-fans-are-better/#findComment-3056070
if you get your hands on the GTs, then the GTs
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/223032-which-fans-are-better/#findComment-3056723
