Why are people so against reference cards? Most of the time the reason is just the cooler. But are they just making a big deal out of nothing
or does this hold some weight?
I just bought the 980 reference, which is why I'm asking
I mean, was it a terrible choice? is it going to blow up in my PC or something? should I return it?
https://linustechtips.com/topic/221320-question-about-reference-cards/
what are u talking about? a reference is fine it wont blow up
Love is patient, love is kind. It does not envy, it does not boast, it is not proud. It does not dishonor others, it is not self-seeking, it is not easily angered, it keeps no record of wrongs. Love does not delight in evil but rejoices with the truth. It always protects, always trusts, always hopes, always perseveres.1 Corinthians 13:4
It's because it's a blower style cooler. That's why everyone freaks out.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
People like to be different, so they buy a non reference card so they can look like a jackie
"Strength does not come from winning. Your struggles develop your strengths. When you go through hardships and decide not to surrender, that is strength" Arnold
It doesn't overclock well, it's a bit noisy and might run at higher temps than some non reference cards but that's it.
It has a major PRO however- It blows all the hot air from the GPU outside the case, which is a huge deal for poorly ventilated cases, which means it won't spread heat on to other components.
I ran with a reference card for 3 and a half years, it was completely fine and it was a GF100 chip that heats up like crazy so I was happy that it blew air outside the case. :)
The reference nvidia cards for their high end cards since titan have looked good, performed well and were quiet.
You can not argue the reference is more silent as custom designs. I do not find them loud, but I know some people do.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
Just wondering. I mean a few sites that I frequent, a lot of people are just super against reference cards. I was kind of curious on what your guys' take was on them.
Reference coolers are better in my opinion because they have better compatibility with aftermarket waterblocks if you ever decide to watercool in the future.
Corsair 350D - ASUS Maximus V Gene - Intel 3770K @ 4.6Ghz - Corsair H100i - G-skill Trident X 2666Mhz 4x4Gb - 2 x EVGA GTX 680 Classified 4Gb @ 1250Mhz - Corsair 860i - 2 x Samsung 840 Pro 240GB (Raid 0)
Reference coolers are less capable air coolers in single card setups than open-air coolrs, that is why people tend to dislike them. They are perfect for SLI configs or watercooling though (Cards with reference coolers ALWAYS have the reference PCB)
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
He said nothing about the reference being quieter than custom designs.
I said it wrong. I like the ref coolers.
So, Am I weird for really liking the design of the reference over the (well I would assume they would stick with the same design for the 980's) 970 from Asus and Zotec?
I mean I think the only thing I'll really be kicking myself about from getting a non reference is the 0 decibel mode that Asus has (that is really cool.....no pun intended)
I've owned a reference 5870, 570 and a 680, only the 570 was a bit loud.  Nvidia has really been stepping it up with their reference design, the Titan blower is just gorgeous, performs quite well and is quiet.  I don't regret buying an ACX 780Ti but there is no harm in buying reference.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
They are a blower type fan design on them (mostly). This produces more sound than non-ref coolers and sometimes they run hotter. But generally speaking Ref designs are better for SLI/Xfire configs as they blow the heat out the back of the case and not spread it within the case unlike non-ref
Quack 🦆
Blower design is the direction that we should go with GPU cooling. Keeping the air in the case, just means you need not only more fans on the GPU, but also you case, and possibly increase their speed to try and get the hot air out.
It also complicates things if you have no opening on the PCI bracket area.
If you have other components, such a dedicated sound card, after extensive usage of the GPU under load, it could potentially cause a problem, if you can't properly get the air out.
The advantage of the design from manufactures is that, if your case is open, or you don't do a long benchmarks, or is in a case with lots of opening and have fans be able to push the air out, the GPU gets great overclock score.
So the GPU with the non-reference design looks good.
BUT, not all reference design is all oh so great.
-> Single slot reference sign tend to include a crappy fan that will break soon after a few years, and is noisy.
-> Old reference design coolers didn't include good blower fans, and the GPU were hot.
The upside of non-reference design is that they tend to put some components of higher grade, and offer a bit more overckability.
A big problem with reference design is that too many uses cheap quality fans that are quiet at first, but after multiple years, the fan breaks, and turn noisy. If if you plan to keep your GPU for many years, this could e a problem. At work, we have a great collection of GPUs. The reference designs, at the least the model we have, tend to get noisy or break after they are old. But the reference design, are still holding up just fine.
So yes, it could be a coincidence, but that is the correlation that we are seeing. And of course, we haven't tested ALL reference card form ALL manufactures.
no it is 100% fine the only difference is that a lot of non reference cards have higher quality power delivery and features
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
