First liquid cooling system #help #part list
After looking some stuff up, it appears that you might be able to fit two 240's in an Air 240. If that's the case (badum ts), I'd go for that if you're gonna be watercooling the components you say you are. Alphacool and Phobya are some good (if not some of the best) radiator brands that first come to mind, since they're all copper (G-Changer 2.0 is anyway) and that'll give you a few degrees C lower in temps. I don't have a problem with the colored coolant (Though Mayhems Pastel does have some perks over what you chose), just be sure to maintain your loop and don't let it go too long without you going in and cleaning it out, which is where that bleed valve is gonna come in handy as mentioned in the post above me. If you feel like you wouldn't be able to do that though, Primochill makes nice colored tubing (UV too) that could sub in for the colored coolant. If you can go with compression fittings everywhere, that wouldn't be a bad choice, and it'd look nicer too. Especially with the mix of barbs and compressions you have now. As far as fittings go, you'd need 8 with one rad and 10 with two. You could probably get away with saving some money and getting barbs for the components that won't be seen through the window and zip-tying the tubing on to insure a nice fit, but I don't see why you wouldn't want everyone seeing your shiny watercooling build. Good luck bro, everything else looks good.
