Hi, i am wondering abut upgrading my GPU, at the moment i have a Radeon 7850 running at 1ghz core and 1,2ghz memory.
Shall a buy another compatible GPU and run in crossfire or put the card on the shelf and buy  a new ??
At the moment most of my money goes to my car audio, so i don't know how much money i want to spend on a GPU, i need some input :)
https://linustechtips.com/topic/215499-radeon-7850-upgrade/
I'd crossfire if I were you.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/215499-radeon-7850-upgrade/#findComment-2951379
if you use a 7870 with a 7850, the 7870 will down clock to the same speed as the 7850. You may want to upgrade to a r9 280x, I upgraded to a asus dcuii 280x and its a nice boost in speed and its real quiet.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/215499-radeon-7850-upgrade/#findComment-2957083
I'd suggest going with something more powerfull. R9 280 maybe?
Crossfiring 7850s just isn't worth it.
https://linustechtips.com/topic/215499-radeon-7850-upgrade/#findComment-2957110
Or buy a last gen card now cheap as chips.
7850's and 7870 models on ebay 2nd hand (with warranty on some) can be had for $80-110
There's one in LTT's classifieds for $110
I'd go that route... then in future grab a more powerful single gpu when the newer ones are out and have been ironed out of all the new bugs that came with them.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/215499-radeon-7850-upgrade/#findComment-2957159
